Wanted >> Bell Housing
celticcrusader
stillwater N.J.
Need Bellhousing for a Deutz F2L411 Engine 410 and 511 engines might be the same
Part number is 3469115
also maybe front motor mount , fuel tank ?
call or text Ed @ 862- 881- 7840 Eastern time
old-iron-habit
Moose Lake, MN
After a google search I just read that all Deutz engines use standard SAE bell housings of the various sizes. Is it something different or do you need a certain sized SAE clutch bell housing? Picture?
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Dam.. I cant tell you how many of those engines I threw into the "metal bin".. to be hauled away for scrap..
I'll keep an eye out tho..
celticcrusader
stillwater N.J.
maybe I will call it a flywheel housing , bolts to rear of engine block and has a SAE opening on other side, because right now flywheel is exposed and in the open air and you could get caught in it
old-iron-habit
Moose Lake, MN
Gotcha, you need the casting the bell housing attaches to.
