Today was probably the most stressful in a long time, by the end I was shot. I pulled a tractor in the shop for
a coolant leak, compressor coolant hose {push lock ends} went bad. While I was waiting for system to drain I
did my usual inspection like I always do, and came to the conclusion it was going to be a long day. I had Jeff
remove left side drive wheels then the right side, a sudden discomfort came over me as I felt my blood pressure
rise.
10-21-21 I replaced all four rotors, pads and wheel seals on both drive axles, $1,500 in parts 8 hrs labor.
I looked at Jeff I guess with a look of pain. All he said was WTF. All four rotors were toast one completely cracked
through, those are 44mm thick new. Ground down to 37mm. Those were installed at 221,000 miles it now had
262,000. If the driver had been standing there I would be in jail right now.
I went to work changing out one side told dispatch to send the boss over when he arrives. The next half hour
was pretty ugly. After he looked at the damage all he said was {I'll talk to him-driver}. My response was { either
you fire him or I'm done because I'm not here at my age to wipe the a$$ of your lackys}. His track record as a
driver is horrible, you can't afford him, he is a huge liability. He has tore up destroyed more equipment than I have
fingers to count.
Boss-So your threating me-No I'm telling you I'm done if you don't remove him today. When your setting in
the superior court explaining why you kept him, do me a favor remember our conversation such as was today.
He came back an hour later, admitted I was right. It's not about being right it's about doing the right thing.
I'm here to take care of your equipment and your best interest. You want me to look the other way-well it's
time I go home permanently. You never understand Chris {I walk the Line}.
Some may think it was a waste to type this-but it is about safety on our highways and what goes in now days
with driver shortage and desperation in hiring anyone to fill the seat.
rise.
fingers to count.
