Volvo L60G
ttrenton34
Ohio
Need some help,
Getting 2 fault codes
1- psid 229-9
2psid 5-11
Anyone have anyway to look up the codes for me please?
Innocent bystander
Kissimmee Florida
229-9
Detection conditions:The engine control unit (E-ECU) registers: that bus communication is missing with ACM (EB52/EB56)
Symptom:
○ Red central warning
○ No regeneration is performed
Possible causes:
○ Open circuit
○ Short circuit to voltage
○ Short circuit to frame ground
○ Defective ECU
I would look at power/fuse for Aftertreatment control module first
Psid 5-11
Detection conditions:The climate control unit (ECC) registers: a pressure (SE8709) higher than 2.24 MPa (22.4 bar) (325 psi) or lower than 155 KPa (1.55 bar) (22.5 psi) when the ambient temperature is higher than 10ºC (50ºF) during the first 10 seconds from system start
Symptom:
○ Flashing air condition indicator
○ The AC-compressor is shut off
Possible causes:
○ The refrigerant charge is either too little or too much
○ Clogged expansion valve
ttrenton34
Ohio
I do appreciate your response it means a lot! I will look at the fuse, I noticed when it kicks the code unit will only rev up to 1080rpms but when the code kicks off it acts perfectly fine(code 229-9)
jean auger
wainwright alberta
heavy duty mechanic
hi ,just wonder if you figure out why psid 229-9 was active ,i have the same code on l90 g and i was hoping to get some advice for you on the issue ,thank you
