Hi,
I looked at a 2015 L110H today showing 11500 Hrs. The loader has 2 fault codes showing on the dash.
I'll attach pictures of the codes. The owner tells me the DEF system ( ad blue) has been turned off and DPF removed. I'd be inclined to believe him as when you rev it full when driving or idle on the yard it puts up a bit of smoke (more brown than black if that makes sense).
It drives good and plenty of power with good crisp gear changes.
I also noticed that there are 2 sensors unplugged more or less on top of the air filter housing and an ECU at the rear right of the engine that has a bypass plugged into it, I'll put up pictures of this too.
Any idea's good or bad or would I be better off to keep away from the loader.
Thanks
Thanks
