Volvo FC2924C showing "Warning: Turn off engine. Engine error."
Jinajon
New Zealand
Thought I'd post a final follow-up:
After replacing the injectors, the rail pressure stopped fluctuating wildly, but it still varied more than I expected. However, the fault did not reoccur, and the machine operated flawlessly, so I declared the problem solved and moved on.
After about a hundred hours, the fault reoccured. Armed with the info from the gurus here, I replaced the next most likely item: the fuel pressure control valve/solenoid. (We had previously tested this component and it appeared to operate fine.) Once the brand new Bosch 0928400670 FCV was fitted, the problem resolved immediately, and notably; the fuel rail fluctuations ceased. (Obviously the rail pressure did alter, but exactly as expected for a PID control system.)
I believe that the FCV was the root issue, and the worn injectors exacerbated the fault.
sfrs4
Great Britian
parts admin
@Jinajon thanks for coming back to everyone with the "solution" as much as we can provide help the final solution is always the best thing to see on here, so when later people search the same problem they will find a hopeful solution to the problem as well.
funwithfuel
Will county Illinois
Mechanic
Please start at the beginning of the thread. Both SFRS4 and I have posted all the troubleshooting steps needed. If you have questions or concerns about a specific test, we will be happy to guide you or explain it more clearly. We are not there. We cannot see or hear how your machine is behaving. We only have you saying," mines doing the same thing" Rarely is it the same outcome.
