Volvo ec290 finale drive disassembly instructions
uffex
Lincoln UK
Admin
Good day
From an earlier model, however, it is a very small difference.
Kind regards
Uffex
  • Volvo CrawlerTransmissions.pdf
uffex
Lincoln UK
Admin
Good day
No sir that makes the information more relevant to your machine.
kind regards
Uffex
funwithfuel
Will county Illinois
Mechanic
There should be roll pins or set screws to retain the planet shafts. Then simply using a threaded puller should extract the shafts. Use a short bolt to leverage against the spanner ring. Use lube and good luck.
uffex
Lincoln UK
Admin
Good day
I thought it looked a little thirsty, be good to establish how the oil got out.
Kind regards
Uffex
