VOLVO EC220E pedal control
stars&bars44
Trinity NC
Earthmoving
Anyone know how to change the 3rd pedal direction that operates the thumb or shear? I cannot find it in computer, tried to switch lines at bottom of pedal but its electric so no go there. When you push it away from you it opens and I feel more comfortable with it closing that way. Any help is appreciated.
funwithfuel
Will county Illinois
Mechanic
Do you have thumb control on joystick. Should be RH stick with slide switch. If you have that, you'll never go back to pedal.
stars&bars44
Trinity NC
Earthmoving
I don't have slide switch. I have run those for years, I like the hydraulic pedal because you can pick up anything softly and not crush it. But this pedal is electric over hydraulic so the thumb option is probably better.
funwithfuel
Mechanic
The slide switch is variable . I think it has to be turned on in parameters. It's a simple install. Its awesome though. Fully variable, super smooth
uffex
Lincoln UK
Admin
Good day
The simple way to reverse pedal control is to switch the pilot lines on the main valve or switch the connectors on the PWM valves if you need better info. PM me
Kind regards
Uffex
