steve waldner
A30c dump truck engine ran out of water, kid didn’t watch gauge , , anyhow the #2 piston roasted and cracked the cyl sleeve , was gonna just fix that piston and sleeve , but skeptical , reason for this post is the oil pan , how to remove with those 2 hydraulic pumps in the way, do I have to remove the 2 pumps to get the pan off? I just did a full head overhaul 2 years ago. I’ll inspect the sleeves from the bottom side , or should I not consider to just do a half as job? Do a full overhaul and walk away. Anyhow oil pan? Thanks guys
