Volvo A35c high gear stuck in first throwing fault code 492
colts81990
Indiana
Have a Volvo A35c that will shift through all the gears in low speed but throws a code of 491. Put it in high speed and it's stuck in first and will not shift up throws a code of 492. Just curious if anyone has seen this before by chance.
sfrs4
Great Britian
parts admin
Whats before the 491/492? is this code on contronic or some A/M reader?
colts81990
Indiana
The codes come on the contronic in the book the code says code 491 slipping turbine speed (input) higher than output speed. 492 code is slipping turbine speed (input) is lower than speed (output)
colts81990
Indiana
Some pictures of the codes in the book
Simon C
Heavy Equipment Mechanic
How many hours on the unit. Is there any other info on previous repairs , or is it just started to act up now. Have you opened the transmission filter and checked the pleats of paper for something coming apart. Does the oil smell burn't. Just asking.
Simon C
sfrs4
Great Britian
parts admin
so as Simon C says, check your filter and oil strainer in the sump, if the oil smells burnt then it's more than probably slipping. this could be down to worn clutch plates or broken pressure plates etc.
ianjoub
Homosassa, FL USA
sorry for the threadjack:
I have an A30c. Do you shift these on the fly or do you select an appropriate gear while stationary and go?
Simon C
Put new transmission in throw same codes still
You probably need to check the harnesses that feed the transmission solenoids for weakness or opens.
Did you open the filter as I posted in post#5 to see what was in. Was the Transmission done by a dealer or did you do yourself. Do you have electrical schematics for the unit, and how about a service manual.
Were gauges hooked up to it and pressures checked.
We are not there and just asking.
Simon C
