ms0115
Volvo A25D
Serial # - A25DV13985
This machine has a SE 2202-3 Code. It appears to be a temp sender oil voltage high. I did not find any wiring issues, so I dropped the pan and replaced the sender. Test ran, rescanned and cleared the codes thru my diesel laptop. There shows to be no faults codes on my laptop, but the code will not clear from the monitor. Is there a trick or any suggestion. Thanks.
