Pocho86
hey
Volvo A25D Serial 15040
So I got some warning lights that came on. Apparently its a Stop light and another light and in manual indicated there is a Brake Over Stroke detected (Leak, Blown Line, Worn Pads, Etc)
I was able to narrow it down to the front LH brake master/air chamber thats stroking the rod out almost all the way.
How Do I Turn This Light Off, is there a reset procedure? Do I need to use the laptop?
I unplugged that sensor on that air chamber and warning still stayed on. I jumped the two wires and same thing. So if its unplugged and jumped and no change, maybe a reset procedure of some sort needs to be done?? Unless I need to ground one of the wires?
