I have hydraulic overheating on the 360BLC and I want to know if someone had already have problem on oil cooler getting clogged or if check valve of the cooler get damaged. What should be the fan max speed on the hyd cooler and the pressure of the fan motor on this max speed. Is it helpfull to test the pressure on the input of the cooler and what should be the max pressure at low idle. Any help will be appreciated
