Volvo 160 smoking
Havoc
Oklahoma
Field mechanic
Well this excavator has been at the Volvo dealer for smoking. They changed the turbo, 1 injector and the cylinder head and inspected the cylinders they all look good supposedly it got good compression and no blow by and it still got oil coming from the exhaust port. So the dealer said rings now.So we Brought it back to our shop to figure it out or something. They want us to check it out, I’ve seen pictures and video but I not sure how much it ran since they changed the head and how hard I’ll know more tomorrow if I have the adapter for this motor for compression and cylinder leak down but kinda thinking about working it a hour to see what happens to smoke any suggestions? Or thought would be awesome
Havoc
Oklahoma
Field mechanic
The story I got that it started smoking and it went to yes van Keppel of course they said turbo didn’t fix the smoke issue so then a injector was tried and no luck so they pull the head and said it need valve guild seal and put a reman head on it and it still spitting oil out the exhaust with no manifold on I will get pic and video sent to me today to up load I kinda want to go work it for a hour and see if it get better worse or what I not sure if intercooler has been or was drained or cleaned I know hoses clean air filter is new now no oil in housing
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
What Dealer changes 1 injector.!!!
THATS some pizz poor diagnosis right there..
If they cracked a line to THAT CYLINDER and it stopped the smoke, great.. but u put in 1 injector and restart the engine and it smokes, u take it out and say, that didn’t fix it and proceed with a leakdown test..or/and a compression test, PAYING ATTENTION TO THAT CYL.!!
Havoc
Oklahoma
Field mechanic
Here’s 4 pic I got more and will get some more l and get the Serial number and the model number and I’ll have a video of it running they’re supposed to be sending me a few more videos and pictures
funwithfuel
Will county Illinois
Mechanic
Looks like a B series with individual unit pumps. Verify that all injector nozzles are installed correctly. There is a dot drilled into the side near where the fuel line attaches. It should point away from you, if memory serves correctly. If one or more are in backwards, you'll get slobber and pi$$ poor atomization . The injector is directional, it sits on an angle to the piston. The piston crown holds your swirl chamber, if the spray pattern is off, everything is out the window.
thepumpguysc, please confirm dot orientation.
Ben Witter
On the outside
Pretty sure FWF is correct. The injectors have to be oriented correctly or the spray pattern will spray out of the bowl in the piston. This usually causes black smoke and can cause some fule in the exhaust which when mixed with soot can be mistaken for oil.
The dots on the injector should face the valve cover if memory serve me right.
Havoc
Oklahoma
Field mechanic
I’ve got a video trying to get uploaded from my phone
Vetech63
Oklahoma
Looks like unburned fuel and not oil. I’ll tell you right now…..Van Keppel doesn’t have a soul in the place that has any experience. They change parts until they get lucky. You probably had a fuel problem the entire time.
Havoc
Oklahoma
Field mechanic
They said yes one of my bosses has pictures of all the cylinders and they look good
funwithfuel
Mechanic
Sure there was, its in techtool. Its cranking compression. It times the crankshaft. The slowest is your 100% benchmark that all others are measured against. So if you got 100 psi in one hole and 98 in all the rest, you'll have 100, 98, 98, 98, 98 and 98. But in reality only enough compression for a weak ass clapped out lawnmower.
Havoc
Oklahoma
Field mechanic
Facts this is my first Volvo and I’m coming in after IMO a parts changer that sunk 30k and still not fixed
