Vancouver Island, BC. Logging at its Best!
camptramp
The warm land on Vancuver Island
Retired Logger Retired Part time pebble hauler
Dave Whiskin Collection Timberwest HBO Div. #40-96 P16 Pacific Pulling a load up "Jack Shaft Summit" . This is a long and fairly step grade from Loop Creek bridge to the Summit well over a Kilometer long . On a hot day with a heavy load , the dust would pass the truck . When it was first built in about 1983 the camp Engineer figured he saved about $22, 000.00 on explosives by leaving a couple of pitchs a little on the steep side . The Master Mechanic figured it cost about $50,000.00 in drive line parts . The grade was beginning to be known as 'Jack Shaft Summit" . One Morning a friend and I were heading out to the Woods early . There is a Rock Face in front of the truck in picture . We pulled our trucks up to the rock face and stood on the radiators of our HDX'sscan437.jpg scan438.jpg scan439.jpg , then with Light Blue paint wrote in letters as big as we could "Jack Shaft Summit" . The name stuck . The grade on that piece of road has been cut down two times before that picture was taken .
petepilot
central shenandoah valley va,
Dave Whiskin Collection Timberwest HBO Div. #40-96 P16 Pacific Pulling a load up "Jack Shaft Summit" . This is a long and fairly step grade from Loop Creek bridge to the Summit well over a Kilometer long . On a hot day with a heavy load , the dust would pass the truck . When it was first built in about 1983 the camp Engineer figured he saved about $22, 000.00 on explosives by leaving a couple of pitchs a little on the steep side . The Master Mechanic figured it cost about $50,000.00 in drive line parts . The grade was beginning to be known as 'Jack Shaft Summit" . One Morning a friend and I were heading out to the Woods early . There is a Rock Face in front of the truck in picture . We pulled our trucks up to the rock face and stood on the radiators of our HDX'sView attachment 215317 View attachment 215318 View attachment 215319 , then with Light Blue paint wrote in letters as big as we could "Jack Shaft Summit" . The name stuck . The grade on that piece of road has been cut down two times before that picture was taken .
kinda looks a little like wolf creek pass except the roads on the wrong side of the hill :)
Hallback
Aberdeen Wa.
Gyppo tower logger
How much timber is left on the island? How much old growth and how much of it is still able to be logged?
Blk prince
Ladysmith bc canada
Truck driver semi retired
camptramp
Someone call my name? Shake the tree and guess what falls out. Haha. Yep,still around. Doing well. Looks as if you gents are doing well. At least I hope you are
Good to know . Bin awhile since the last load of logs went over the "Brow Log" , the last load of "Pebbles" has met the same fate . When this latest social set back passes over we'll have to get together for coffee . Take care Bp stay healthy .
Blk prince
Ladysmith bc canada
All true sir. Yes we need a good chat. It will happen. Take care also
camptramp
Is that steam or smoke from the brakes and why only on the trailer?
Yes that is steam coming off trailer brakes . The #40-96 P16 Pacific came with a V12 natural Detroit Diesel engine with an Alison 6 speed power shift transmission with a built in drive line retarter . In the late 1990's the truck was repowered with a signature 600 Cummins engine Equipped with an engine Jake Brake . So when this picture was taken this truck had lots of braking in it .
The water to cool brakes feature starts with a water tank behind drivers cab . a water line comes out the bottom of water tank on drivers side , a hose runs up to the cab floor by door side of drivers seat , there is a main pipe that has a dump valve built into it which then goes to a "T" , on the front side of the "T" is a water valve that controls the water flow to the truck brakes , an elbow in the pipe sends the pipe down through the floor to the truck brakes . A pipe goes to the back side of "T" with a water valve that controls the flow of the water to the trailer brakes goes to an elbow and down through the floor to the trailer brakes . There is an air shut off valve and a gauge under dash to set air pressure to water tank to push water to trailer that is usually higher than truck going down steep hills . As there is a hand valve to set air pressure to trailer brakes , the driver can use more braking on trailer than truck . And by using the Retarter and or Jake Brake the driver uses less truck brakes . So Dave is using lots of trailer brakes and minimal truck brakes . Its interesting that the water nipples or spouts spray the water across the brake drum from the inside to the outside , as the brake drums are slightly tapered , the water that stays on the brake drum is pulled back to the inside of brake drum and runs on the ground inside of tires .
Thanks for the explanation. How many hours or miles will one of the off road trucks go with reasonable maintainence and a good driver?
camptramp
That's a good question . The HDX Hayes was a very good truck not very many Off Highway Log Truck drivers got a new Logging Truck . That honor usually went to one of the senior drivers , who often got more than one new truck in their career . As a junior driver I got the #222 at BC Forest Products at Renfrew Div. in 1981 , I'm sure the Speed o meter worked when it was new . But that was in 1962 , I can't remember the hours on the hour meter , but it may have been changed over the years . I hauled its last load of logs in fall of 1982 . There was nothing wrong with the truck , some newer and bigger log trucks had come available from some other BCFP camps that had been shut down . The #222 was used around camp to move (Fire) water tanks and trailers for a couple of years then a water tank was mounted on the back and it was used for Fire Protection . Last I heard of it , it was owned by IPL and still running . The HDX Hayes , P16 Pacific , 849 & 850 Kenworths as was the Challenger all had "I" Beam frames . Excluding a major mishap that caused the frame to be badly bent , these trucks just kept going . As times changed in the Forest Industry some perfectly good Log Tucks were victim's of a major break down , lose an engine or major component , the next thing you know other parts were taken off it to keep a similar truck running .
In the bigger operations I think the accountants had a lot to say about how long a logging trucks productive life was . After it was written off and a new Log Truck was budgeted to replace it , most of the old off highway log trucks were repurposed as Water Trucks , Rock Trucks , Sand Truck or as a Linehorse .
Just an after thought . the #40-96 P16 Pacific was the newest Off Highway in HBO in was built in August 1980 these pictures were taken in 2001 and I think it is still running !
Hayesno1
Denmark
Project manager
I think #222 was sold last year but I don’t know to who. There are quite a few contractors that are running small fleets of old off highway logging truck. I know Wahkash has at leaset 8 Hayes HDX and 1 Mack CL350 running. Mack truck is from late 70´s but the Hayes trucks are from the 60`s and early 70´s. Pretty impressive!!
