Congratulations on getting it out iin one piece.Got it out. No way a new valve cover gasket was installed last May before I bought it. Maybe the upper, but this bolt has not been removed before.
What they referred to as the "valve cover gasket" may have been only to top one. Correctly speaking the top one is the cover, the bottom one that you have just removed is the valve mechanism base.
It might be an idea to run a plug tap down all those threaded holes before you reinstall the bolts to make sure there are no hickeys in the threads anywhere, although TBH it looks from the photo as though it could have been corrosion on the shank holding it rather than the threads.
Refer back to post #2 for the suggested hardware tightening procedure.
