Pretty normal, forklifts are hell on refers. Those rivets are blind Huck 1/4" not hard to get.
As far as the Kemlight wall bulging that's common too with age. Refer repair shops carry
kemlight in sections or small pieces. The sealing caulk to use is Bostich FS 1100, that stuff
really sticks. Main thing is the floor in decent shape? The Aluminum channel where the forks
run gets shaved sometimes real bad, especially with slip sheet machines. It's like a big scrapper
on that aluminum, just files it right down to nothing. Is the floor {if it has a slider/or not} in
front of slider support good not cracked. Real common for that area to crack on older trailers.
From photos it doesn't look too bad-nothing that can't be repaired.
Can also call it a sprayer tender, it's a farmer term for a van trailer with 3 - 1600 gallon poly tanks connected together, mixing cones, transfer pump and hose reel to haul water and chemical to the sprayer for crops. During spraying season, if you are covering 1000 acres per day, you need 10k to 20k gallons of water. The reason we use reefer trailers is they have an aluminum floor that won't rot out.What's a spray trailer?
Which part? That we use semis to haul water to spray, or that we use that much lol.Cool. Thanks for the info, learned something today.
We sold some old Utility trailers some years back for storage units--Those would have madeif you are covering 1000 acres per day, you need 10k to 20k gallons of water.
Most in this area build ten wheeler or 45' flat trailer spray tenders, This is similar.
There are a few around here that use a van as well, mostly old ones with a right sideSome guys do this as well. We like the enclosed trailers because the tanks will last pretty much indefinitely, and the chemical is out of the elements as well. Also, chemical is supposed to be under lock and key, so these make that possible as well.
It's the best of that type of trailer--the rest are all trying for second place.They seem well built
