Why?
Because there light, cheap to build and the plastic dissipates heat fast.
Why?
No aftermarket pans available for the 2.7. Apparently the pans have special baffles in them so oil drains slower for the start/stop feature. Newer engines use a neoprene gasket or something like that but it can't be used on the older engines. I think some of them are leaking too. I think the 3.5's went to an aluminum pan and there is an aftermarket available too. The latest TSB is supposed to fix the leaking if done properly but is an expensive repair.
The difference between then and now.
In 1961 my dad bought a 1960 Ford Ranch station wagon-{back when they still made a thing called a station wagon}. We didn't have it six months and the transmission went south,
then a electrical fire and after that brake issues. If I remember correctly it spent most of late 1961 at the dealer he bought it from. His complaints went no where and we were lucky
at the time to still have the old 52 Plymouth potato car to drive. So he went to the bank that financed that Ford and told the head banker the story. The banker grabbed his hat and
told dad we're going for a ride and see those folks.
To make it short-The banker told them he financed alot of cars from that dealer and the car that they sold my dad was a lemon and they better take care of it by getting him a new
or different car of equal value when he bought the car. That dealer rolled over and took the car back and he drove away with a new 1961 Ford Wagon. It was a pretty good car.
Those days are long gone your just a account number, and nobody really cares. It's all a roll of the dice.
Start/stop has been trouble free. Eco-boost are good engines but they needed to pay more attention to a few things like the oil pan leaks.
Seems strange,
Dealers get paid for doing warranty work by the .mfr don't they ?
I would think the would be eager to do all the warranty work they can get.
Dam, Dave you deserve a break.
My nephew has a 2019 Ford super duty 250 and it has the famous front end shake.
They haven't been able to fix it yet.
From what I have read dealers sometimes have to be careful of how many warranty claims they put in. This dealer is in a smaller market than the big city dealers. If they put in more claims (per capita) than a bigger dealer might raise red flags for Ford with more claims denied. The other thing I've read is that warranty work doesn't pay as much as what the dealer could charge a customer and sometimes the work takes longer than is allotted. I can see a busy dealer wanting to do more customer paid work and getting full retail on parts supplied. I don't think a dealer makes any markup on parts for warranty work as they are supplied by the OEM.
A lot of the problem is with Ford but but despite what the dealer is telling me, I have no way of knowing how much the dealer actually went to bat for me or what was actually communicated to Ford. Did the fact I got the service agreement done on warranty somehow negate getting the oil leak on warranty? There is an arbitrator you can have look into the issue but I think under the circumstances the oil leaks at least should be covered fully under the power train warranty. I hope to talk to the other dealer tomorrow. I'm not giving up without a fight on this one.
My wife has a 2020 Lincoln Avaitor (Lincoln version of the new rear wheel drive Explorer) with the stupid stop-start 'feature.' There's a plug and play bypass kit to permanently disable that 'feature,' I will be buying one. It can be disabled in the menu but it resets every time you shut off the vehicle. Why put 10x or 100x the wear on the starter so Ford could make their mpg numbers?
Warranty work does pay less, but in the last year or so many if not all dealers have been slow. They've been bugging the hell out of me and everyone I know begging to bring vehicles in for warranty/recall work. A few years ago when things were busy it was the opposite but right now many are going the extra mile to get things covered to bring them work. I think a big city dealer would be a better bet. If they want to get it covered they have a lot more pull then the little dealers. However time is against you, the longer it waits the harder it will be to get covered. Do you have it well documented about contacting the dealer at the 1100 km over or whatever it was?
I'm not trying to hijack this thread. but ----->https://thelemonfirm.com/2019/12/13/be-afraid-be-very-afraid-of-the-ford-super-duty-death-wobble/Stock truck? If it's stock, the geometry is out of whack from the factory and the dealer should be able to get it back in line.
I played hell when I leveled the front of my F350. Finally got it right after a dual steering stabilizer and Carli track bar.
Won't be leveling anymore trucks in the future as long as Ford offers the Tremor package.
Where I work I had a 95 Super Duty [450] that had the death shake if you didn't put a steering stabilizer on it every 18 months. If you did that, it was smooth as glass.This issue goes back into the late 80's with the super duty including the 2WD's. As far as I know Dodge has not had that issue with solid steer axles. The death wobble as it's called is violent
as hell in some cases. As I said before the Ag company I worked for had four that had that problem those were all 2WD and all had the issue under 30,000 from new plus it only took 40mph
to set up the shimmy. Tires were changed, springs, panard bar, shocks, tie rods, king pins including the steering boxes and column joint by the dealer to no avail, plus several independent
alignment shops checked them. When I worked for that company one driver fractured his wrist trying to keep it under control at 50. All four ended up under the lemon law. The years of the
companies super duties that had the issue were from 89 through 94. Steering stabilizers were installed to try and mask the problem but that's all it did was mask it. When I see a large ford
coming my way I keep an eye on it.
