Northart
Ist time I seen this in person. Lucked out when they had one in at NC.
I like the flip down ripper teeth, they dig in when going back wards and slide on the ground as you push forward, very neat.
[-Agent-];71122 said:^ I did. I bet they could make a bridge for the other stuff to get across. It almost looks like a modified challenger.
looks like the bison that deere making
Indeed -- perhaps the Bison wasn't aimed squarely at contractors (some of whom are obviously lamenting its merits), but also at the military. The Deuce is getting long in the tooth, and even though the military has a habit of running machines into the ground, it's due for a freshening. Looks like they may have their answer.
Ron i agree i like the backup ripper system.You see them on dozer around the oilfield the most it seems.
They would work good for my operation since i would only be using them for ripping hard dirt during the dry time,it that ever get here:beatsme.:usa
d6peg have you noticed any accelareted pin wear? u/c wear is usually worse backing up, now your applying load in reverse. just wondering???
