Hi everyone!
We are hearing an unusual noise from the hydraulic pumps of our Hitachi EX300-1. It has twin axial piston pumps.
The noise is difficult to describe but it is erratic/random and the pumps sound stressed (Attached is a short video of the pumps making the noise).
It does not sound to me like the typical cavitation noise which I understand is more of a high-pitched screeching/whining sound, or gravel passing through the system.
While doing a hydraulic oil change (after noticing the noise), we found metal debris stuck to the hydraulic suction screen in the tank (Video attached). It looked like brass debris. Around one fourth of the suction screen was covered with this stuff and the oil had some debris in it as well. The excavator was recently fitted with additional piping for a hydraulic breaker and we suspect the debris entered the tank due to faulty workmanship during the piping installation. Though we cannot be absolutely certain if the debris came from our own pumps' cavitation, which is certainly a possibility, the hydraulic return filter was found to be clean when removed. Today, we drained the system of oil, cleaned the tank, changed the oil and filters but the noise still persists.
The machine was run with a bucket attachment for around 20 hours after fitting of the hydraulic breaker lines was completed. We have noticed that the machine is working slightly slower than before the noise appeared. However, we have not noticed any large or constant vibrations in the hydraulic hoses nor were the pumps heating up excessively.
I understand that an inlet restriction is the most common cause of pump cavitation. It could very well be that the damage has already been done, but I wanted to positively assess how bad the situation is, and whether we now need to get the pumps disassembled and repaired; any advice on the possible way forward would be greatly appreciated.
I was reading on another forum (
) which said and I quote "Because of their lower flow rates, plunger pumps typically have fewer cavitation issues". So I am really hoping the partial inlet blockage did not have a detrimental impact on the pumps. Extremely stressful situation!
Thank you
Muneeb
What is Cavitation in Pumps? Learn the Causes and Cures
What causes cavitation in pumps and how can it be prevented? Understand the causes, cures, and considerations.
www.pumptec.com
Thank you
Muneeb
