tl;dr: What do you do when your service provider disappoints; make them fix it, or give up and go somewhere else?
I bought a 2015 Vermeer FT100 with 620 hours in a private sale last May. The FT100 is a rebranded Terex PT110 Forestry (my machine) / ASV RT120 Forestry (current machines) with Vermeer-engineered rotary mulching head. I got it for a good price—maybe too good—and had it delivered to directly my local dealer, with whom I had no previous relationship. I asked them to give it thorough inspection and fix anything that needed to be fixed. They found $2000 worth of this and that, but no serious issues.
After some delays it was delivered to my property, ~47 acres that over 50 years went from farm to forest to logging site to impenetrable tangle of logging slash and buckthorn. I ran the machine for about 45 minutes, keeping one eye on the on-board computer. The reported temps all stayed low, but when backing up, I noticed a bit of steam out the side window. I turned around to see the radiator erupting like Old Faithful. These machines have poor side and rear visibility, so I'm not sure how long it was doing that; it could have been several minutes. I boiled away over a gallon of coolant :-(. Back to the dealer to figure out why it was overheating and fix the resulting damage.
It was at the dealer for three months (!!!) working on the problem, waiting on parts, tech on vacation, etc. They did eventually find the root cause: a broken spring in the oil cooler bypass release valve, which allowed hydro oil to bypass the oil cooler and return to the sump directly. (Come on ASV, shouldn't activation of the bypass valve throw a warning?) It is possible this spring had been broken for some time, as there were two hydro oil overtemp fault codes in the computer and the dealer said the machine had other service visits in its history. The dealer fixed the value, replaced thermostats, and a few other parts.
I finally got the machine back at the end of August along with a hefty invoice. Cut some paths, shredded a few acres of invasives. Fun stuff! I know the ASV undercarriage is one people love to hate, but the combination of low ground pressure and 15" clearance is a great fit for my working conditions, which is poorly-drained glacial till with stumps and no rocks. The Vermeer mulching head is awesome. I put about 45 hours on the machine last fall and learned (maybe from this forum) to sharpen the teeth before every use, which makes big difference in cutting efficiency. I kept an eye on the hydro oil level; it went up and down but it was hard to see if there were small losses because overnight temperature variations make a big different in oil level also. However, after a mulching session in January it started leaking very badly, with oil visibly dripping from the belly pan. Back the dealer.
This time they reported that a bunch of hydro hoses need to be replaced along with all 22 gallons of Vermeer brand hydro oil at a cost of approximately one zillion dollars per gallon. I assume the hoses were a casualty of the earlier excessive hydro oil temp, or maybe just age; what can you do. After another month in the shop waiting for parts and another big invoice I got the machine back last Friday. The machine was out of service exactly during our one month of actual winter, but the ground was still mostly frozen on the day it came back so I ran it until dusk that evening. Checked for leaks after shutdown, nothing obvious, but it was getting dark. I left the machine for a week due to my real job and warm weather. Yesterday morning I went out at dawn to take advantage of a cold night. A check under the machine belly pan revealed it's still leaking oil.
Today I opened up the cab and dropped the belly pan to see what is going on. The pumps and hoses look ok, but I found the dealer had used some kind of RTV goop to seal around the hydro reservoir as well as in various other inappropriate (although probably harmless) places, like hose-clamped hoses. Looking at the parts diagram, I see the access cover calls for an O-ring rather than a gasket. As an engineer, I take a pretty dim view of using goop instead of a gasket, but using goop instead of an O-ring is just appalling. There is absolutely no way that will work. (I know they didn't replace the O-ring, because they didn't charge for it!)
So the question is, what do I do now? My repair bills to date are over 20% of the purchase price. In one of those "for the want of a nail, the battle was lost" situations, the use of goop instead of a couple of $20 O-rings means the hydro oil will likely need to be dumped again. (I did at least determine today that Vermeer Ashless is probably Mobil DTE 10 Excel 46; that'll save a few bucks.) It's not practical for me to work on this machine myself; I don't have the experience or tools, and my "shop" is gravel driveway without water or power. The dealer is local and friendly enough, and it is clear the mechanic spent a lot of unpleasant hours digging into this machine, but by their own admission they had not worked on one of these machines before and this O-ring business suggests a lack of expertise with hydraulic systems.
So, do I call them and read them the Riot Act, or do I give up and look for a different shop? If the latter, how do I find a shop that has some experience with ASV machines? I'm in the Cleveland area; the nearest ASV dealer is in Columbus and they only recently starting carrying the line. Other options include a couple of agriculture-focused dealers in the next town over, and various construction equipment dealers (including a giant Ohio CAT franchise) ~50 miles away. I realize there's some chance this machine is just a lemon or was damaged beyond repair by the overheating but the engine, undercarriage, cylinders etc are all in fine shape, and I'd like to think it can be fixed. What do you recommend?
Thanks,
Rob
belly pan where the leak is:
hydro reservoir access panel with goop and oil:
Oil return panel. Amazingly, this doesn't seem to be leaking.
Parts diagram. 43, 44 are O-rings.
Thanks,
Rob
