Undercarrige jungle?
D6r
sweden
Hi there, i have a d6c 1971 and i am looking for some good used tracks + pads. Does enywone knew what kind of chain it is on my machine and if it`s the same chain on somewone else dozer that wil fit on a d6c? I`s there a standard model?
Old Magnet
Corralitos, California
What track link part numbers do you have now? Track pitch is 8.00 inch and comes in either 5/8" or 3/4" pad bolting. Sealed and sealed and lubricated options are available. There are some interchanges with other Cat models that also use the 8.00 inch pitch as well as interchange with some Komatsu models.
D6r
sweden
Hi, thanks for answer, where do i find the track link part number? There is 3/4" bolts.
Old Magnet
3/4 bolting would be a 3P1112 RH and 3P1113 LH link number and would be visable as a raised number on the links. Same link used for both sealed and sealed and lubricated tracks.
Could also be a former 7S9109 RH and 7S9110 LH link number.
D6r
sweden
Thanks, i will check in the morning.Is there a standard track that sits on deere and komatsus also?
D6r
sweden
Hi again, i found the numbers 3P1112 as you said. So maybe some komatsu dozers chain will fit, it will give me some more option when im looking around for some used tracks. Thanks for info.
D6r
sweden
Does anywone know what colour code it is for cat yellow 1971? Also i wonder where i can buy new stickers cheep for my d6c al around the machine?
QuickTrax
Houston
The D6C chain is the same as the JD850C. It does not fit any Komatsu or Case equipment.
Good luck, QuickTrax
Old Magnet
That must be a later chain as my Cat literature shows the 8.00 in. pitch chain for Komatsu and the D6C as using the same sealed track link assy 3P1088 part number.
QuickTrax
Houston
I am also taking bolt pattern into consideration. The Kom. D65 does have an 8" pitch but it doesn't have the same link as the D6c,d chains.
Old Magnet
My 1989 Caterpillar Parts Sales Kit Form PEKP9100 shows a whole list of D6C track shoes that fit the 3P1088 link assemblies (same as Kamatsu D60 & D65 with 8" pitch) using the same 3P1112 RH link and 3P1113 LH regular links......What gives????
There is a fine print note that Cat and Komatsu shoe bolt hole patterns are not interchangeable. Does that mean even though the link and assembly part numbers are the same, they are actually drilled different?
Even if the pad bolting were different, would they not interchange as a complete pad and chain assembly?
QuickTrax
Houston
They will have different bolt patterns. I believe you can use the D65P conplete track on the D6C,D but would have to adjust the link count.
