treemuncher
I've done a lot of searching for dimensional data with very limited success, both here and on the net. I'm trying to find dimensional data for interchange-ability of undercarriage components. Maybe there is something else out there designed for excavators or other dozers/equipment that might fit my needs.
My Lamtrac uses a Deere 450/550 size undercarriage with standard rollers and SALT rails - easy to source and purchase. HOWEVER, the sprockets are on excavator style drives (Brevini) with a 21 tooth count which is just about impossible to find other than OEM. At over $1,200 per sprocket via OEM and lasting only about 1,000 hours, I feel like I'm being bent over a barrel and taken advantage of. They don't even have the decency to use a lubricant. My starfish is very unhappy as is my wallet. There must be a better solution out there, somewhere.
450/550 drive sprockets are easy to find in 23 or 25 tooth counts but I can't find the dimensions to see if they might be able to fit my application. I could have parts water-jet cut and welded up likely cheaper (and likely longer lasting) than OEM. I was able to find a former part number 050508 that had the 20 bolt holes at 16mm with the correct 21 drive teeth.....but no longer in production and out of stock.
Any suggestions from those that deal with this stuff more often than I do?
