Hi I have a hitachi mini ex-35. I just rebuild the Kubota motor. The hydraulics were all strong and fast prior to the engine work. I reinstalled the pump when installing the engine, refilled hydraulic oil and bleed the air out of the pump with the Allen screw and hydraulic lines on the pump. I can’t get pump pressure to run the cylinders at a normal rate. When at idle they run faster then with higher RPM’s, there is no whining. There was whining initially then I shut it down and bled the system. I’ve attempted multiple bleeds but I suspect an air issue as the speed decreases when RPM’s raise. Any suggestions? All functions are slow, blade, tracks and stick. It has a Nachi piston pump.
