orville
I am in the process of buying a 1988 Ford F800. The two speed axel is in the low speed and will not shift out of it. I know there is a switch on the shifter stick that is supposed to change from high to low and vice a versa. What makes things not work. Is the problem in the axel or is it electrical. The man selling says the problem is the switch on the shift stick. I am guessing a solenoid on the axel does does the shifting. I would also guess not to shift under a load. Any suggestions on the problem and how to fix it.
