Thanks for the pictures! What are the capacities of the two pin on axles?
The red pin on axle is a modified semi trailer axle, if you had duals on it, it would handle 20k. I only have to put about 10k on it to get legal, so I just run singles on it. Less rubber to scrub while turning.
The black one is a old 20k steer axle, I've only got 385's for rubber on it so I think they would be good for 18k, I actually only need about 10k on it also to be legal.
The reason I oversized the axles so much is that in sharp dips and areas, you can really point load a rear axle very quickly. The black crane is around 60k on its drives (without the 2 extra axles), a too light axle back there is a recipe for disaster, or at least bent up iron.
I got both axles from a local truck junkyard, they had both been under dump trucks as extra axles, they usually have a row of 8-10 of them, and each time I just drive up and pick out something I think will work. I think I gave $500 for each axle, then built the rest of the frame from frame rail from the junkyard, and built the pins and brackets, etc. for the rest.
"When in doubt, build it stout!"
