Yair . . . I don't understand the comments here about concern with glowing turbo's.
Forgive my ignorance but I've seen enough of them to believe it was 'normal'. I have seen the turbo of a D353 in a trawler glowing white hot for hours . . . white hot to the extent it was transluscent and you could actualy see the movement of the rotating element inside.
Same thing with scrub pulling tractors, D8's, Allis 21's, full load at wide open throttle for ten hours or so and the suckers fairly glowed . . . same thing with the Schwietzer on the "B" model. At 150--170,000 pounds I always used to prop the bonnet sides open on a big pull and you could see the glow of the turbo if you poked your head around the side.
What's the go? Folks here saying this is not normal? Just asking.
Cheers.
