Trying to get some info on this model JD
CT18fireman
Brookfield, CT
Owner
I could not find a model number or plate on it. Its a John Deere and has a 4cyl gas motor. From the New Milford Tractor sticker on it (I know it has to be 25+ years old)
Any help?
bill onthehill
pa/ny border
Just an eyeball guess I would think 40 years old. Look like pre 310 series. Did you look good along the foot plates and under the battery box areas for a metal ID plate?
pittedmess
maryland
mechanical engineer
The B was only made in '73..my goof..The 300 from '65 up.. That grill may have been a JD option. The hood still has the same shape on the top front edge..Engine should have a serial number on the right side..may give you a range..If not you can go by casting numbers...
