Grit
I hope this is in the right place. I didn't know where to post this because it has to do with two different type machines. If not in the right place I do apologize mods.
I have been looking for equipment to help me clear land. I have a small 16 acre plot in East Texas. Mainly sandy loam on the flats with a slight grade of about 12-16 degrees. There's a creek that runs through the middle of the property. The ground is semi-firm to soft depending on area.
I will be removing saplings and trees no larger than 4-5 inches in diameter. There's lots of downed trees (mostly pines) that I need to clean up. Some of them very large and will have to be sectioned up with a chainsaw and taken away. Some brushy areas with mainly grasses need to be uprooted and cleaned up. Lots of small limbs and debris. I have many (huge) piles of cut logs and brush that will need to be moved to my burn pit as well. I have a lot of widow makers on my property that need to come down and have yet to figure out how to fell the trees. They are much bigger than are in my plans and may leave them for a professional company. But, I have to work around them and try and avoid backing in to one while clearing. Many have already broken off and the base and are leaning against other trees.
Anyway, with a little background on what I'm up against, I have researched (extensively) the equipment to get the job done. We are on a limited budget and can only spend so much on a machine. I have narrowed my choices down to a couple of machines.
I had looked into ag tractors and found that I could get more bang for the buck purchasing a used skip loader. Much more capable machine and I could used the box blade for maintaining and grading my driveway. I was thinking of continuing my drive and completing a circle drive one day and the skip would be a good choice for that as well. Whoever graded this place when they built it didn't know what they were doing so it needs to be graded properly for proper drainage. Of course I will have to learn how to do this myself! The skip will have a 4 in 1 bucket. This may or may not get me what I need and may have to purchase a root grapple in the end.
My second choice is a Compact Track Loader (CTL). Ideally, it would be a safer machine for the job I need to do. But, the maintenance has me doubting this would be a good choice. I am not a company and these machines are for personal use. There's no way I can put money back in to the machine or write it off. So any machine will be a drain on my wallet. The less drain the better. On top of initial cost of machine, I will have to purchase a root grapple for it; Unless I'm lucky enough to get one that has one already on it. Highly unlikely.
My questions are: Assuming that both machines will equally get the job done, which machine do you think will require the least amount of maintenance? Is one or the other easier to work on? I assume the skip would be easier to work on? As far as parts, are parts more expensive on the track loader vs the skip loader (not including the under carriage on the CTL)?
I realize I could get the job done faster with a CTL. Less time on the job will mean less maintenance and less fuel spent. But the skip gets better GPH in fuel that the track loader?, but would work slower. I assume parts cost would be the deciding factor in machine selection?
I plain on buying used and NOT new. Anywhere between 20-30K. I am not interested in any other type machine and have already researched all other types. I feel these two would work best in my case.
Sorry for the long post, but I really need some advice here. I know a lot of you are business owners and have had first had experience with costs on these machines. I need to keep costs as low as possible, but still be able to have a productive machine.
Thanks for any and all information!
