CM
I agree the total should be close to $15. I have tried to take care of it, but it has had some cowboy types on it from time to time, and while it does some work in good conditions, it also does a lot in rocky areas, and concrete demo as well.
I have put 2400 hrs on it after buying used with 1400 on the meter already. It was on with what the original owner said was the secont set of rubber, and he said they were replaced at 800 hrs. I ran them until they looked like rags, and one side finally broke at 2200 hrs. I put new everything on it that time. Tracks, rollers, idlers, rebuilkt the squirrel cages, as they were so loose they looked about to break at any time. I bought all original parts from Cat, and it came to about $16K, plus my own labor to change everything out. Ouch! I saved all the old parts, as some were less worn than others. I ran those to 3600 hours, when one side broke on a job. I brought out my old rag from the time before, and put it on to get a couple hundred more hours.
This time around, I didn't have the kind of $$ to go first class. I bought aftermarket tracks, and for the rollers and idlers that were worn past useable, I mixed and matched with the old ones from before to get an acceptable mix.
I do not expect to get the life out of this combination that I got before, but I did get it together for $4K plus my labor. I know the next time, I will be back to another $16K bill to make it right, if I don't trade out the whole machine by then. I am hoping for 800 hrs or better, but am not sure I will get there. the aftermarket tracks have had trouble staying tight, and the mismatched rollers don't help it any, but, baby has new shoes!
Even with these costs, I do work with the 287 that no other single machine could do. It will run in mud you can't walk in, sand that leaves anything with tires stuck, tight areas that even a small dozer won't fit, and it is so versatile. It is a forklift that will load 5000# items, and move 7000+# items if you can skid them. Just last week, I loaded a piece of 54" RCP on a trailer with it and that weighed about 8000#. I was picking and carrying through foot deep mud with rocks in it 36" RCP weighing nearly 5000#
I do asphalt and concrete removal, brush clearing, and about any other thing you can think of.
All this with a single tool that can be mover behind a pick up. I figure for a small job it is a dozer, loader, forklift, and material handler, all rolled into one.
I know people who do a lot with rubber tired versions, but they can't touch the versatility or performance of the tracks.
Keep in mind, with a tracked machine in an area where rubber would be better, like rock, concrete, asphalt, the track version will perform just as well, or even better, just with a higher operating cost, but a rubber tire machine in a place you need tracks will either perform very poorly, or not at all, so cost is not an issue for you because you just can't do the work.
All in all, I will take my expensive tracks every time, unless I had enough work and money to own one of eack, and only take the rubber tire one when it is justified.
