Truck tires
Below are the major tire brands and models I run on company trucks.
Toyo M122 trailer tire works well on three axle trailer.
Yokohama RY023 tag and trailer. As a tag it works better than most at 255/75. As a 295/75 for trailer works real well
on three axle trailers.
Firestone 591's for steer average mileage 90 to 100,000 miles.
Yokohama 527 drive average 145 to 155,000 miles.
Double Coin RBL400 drive average 160,000 miles on four axle tractor, 190,000 on 3 axle tractor.
I post these because the biggest expense is tires and fuel. These are the best for us given the 32nd's and price.s-l1600.jpg yokohama-ry023-b-255-70-22.5-n925186-1__19579.1621636142.jpg yokohama-ty527.jpg 6004903a-c38a-488f-bb78-af1db6dd336b_1.5de5c33cabc06a94f8173f1b7898f282.jpeg
Aarons81
Central Ohio
Any suggestions for trash/ roll off trucks and flat tires from jobsites or the dump? Also was wondering what your thoughts were on the liquid puncture sealant.
Junkyard
Claremore, OK
Field Mechanic
I’ve always had good luck with the RY023’s on my lowboy and the 4th axle on the truck. I discovered another Yokohama all position tire that is badass on my lowboy. I do a lot of scrub and tight turns, have to jump a curb now and then, gravel roads yada yada. MY507 is what they are. Kinda have a drive tire look to them but they are awesome. In the 9 years I’ve run this lowboy, pushing 300k miles, they’re the only tire I’ve worn out. No weird wear, no sidewalk gashes, no patches or plugs. Just flat wore them out. The first and fourth axle spend as much time sideways as it goes rolling down the road it seems like. They just hold up awesome.
The RY023 does real well on three plus axle trailers, takes the side scrubbing from tight turns on asphalt.
Old Doug
Mo
Do you guys inside tires wear funny ? I blame it on the rutted highways. I had a deal happen i was at the scrapyard with my f600 backing up to dump when i heard a bad air leak i though i just cut a tire on something i started to pull back up when i look forwards i saw a trailer about 200' away that they were working on the brakes they had caused a air leak some how. I was going to use the f600 yesterday it has a inside tire flat its not to bad because i aired it up and it stayed up for the 12 mile trip. I have been lucky i think i have hauled with it 5 years and this is the first flat.
