All new hoses it is! I turned them. They were in rough shape anyway. I think I will buzz them on the other end. I'll install those easy adapters like the middle ones, boy were they easy to turn. The rest, not so much. Probably because they weren't supposed to. :beatsme Being built in 1952 I can't really complain though.
I'm kicking myself though, if I would have dropped the hoe, I could have stilled used the tractor. To late for that as I'm head first in.
Got the valve bank off and have questions. At the bottom of each is that cylinder, which has a hole in it. Some have a plastic plug, some have nothing, and one has what looks like a bolt/washer/nut. They leak a bit. Is there supposed to be fluid down there? Or is that a bad o-ring somewhere?
Found the culprate, one of the bottom cups had blown out. When I used that valve it spewed fluid. I wouldn't have noticed had I not had my daughter up on it while I was watching. Any idea where I can get a replacement part for that? The way it sits Im not sure I can press it flat again.
Also there seems to be an extra hose to the swing, not sure what for.
How do I clean this thing? I don't want to put it back together iwth grit and paint flakes getting into the lines obviously. I imagine hitting it iwth the hose would not be to good either.
Here I'm destroying a hose, unknowingly at the time. It crossed my mind but "nah, it has to be this way".
Here's the issue. You can see it's not flat, so it wouldn't seat. It's the left stabilizer. I was working it pretty hard to lift the back, it didn't want to go and kept seeping down.
