Do you guys over the pond not have random compaction tests by the highway authorities . Over the 30 odd yrs i've been involved in open trench operations in the mains renewal gas industry ,i've dug/backfilled miles and miles of it . Typical system for us is
Dig track
Blind gas main with dirty sand as we call it
150mm 0f fill ..compact ..marking tape.. 150mm layer ..compact and so on .
All done with wacker/jumping jack sometimes 3 of them at same time . Never had any problems with worn out wackers (always properly maintained )Obviously the bigger the main the bigger the trench the bigger compactor . Final layer is tested with a CLEGG IMPACT SOIL TESTER . If my memory serves right ,we aimed for 25% to 31% on main roads ,19% to 21% on footpaths .Company had about 40 to 50 4 man squads for mains work and 20 od 2 man squads for private and industrial service work .Just a little insite just incase you guys think i'm blowing wind up your asses . Kinda miss working in the streets .
We have used compaction wheels on bobcats ,but with the amount of street furniture it isn't always viable to use . Plus our climate and ground conditions don't suit plant that uses high vibrations to get the compaction because of the high moisture content in the asdug it just causes problems hence why we tend to use whackers because of their lower frequency vibrations.
Here's a link to what we have to adhere to. Company i worked for worked to the letter ....
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/11042/sroh.pdf
