Jumbo
CDF (Controlled density fill) 35% cement 65% sand is one mix we use, I also think there are several variations of the sand/cement combinations, but that seems to be the standard I get when ordering CDF.
I have been told by inspectors and in the specifications that pea gravel is the only material besides CDF that does not require compaction. I use that in special applications like a vault that I will need to access to 6 months down the road, since it comes out easy with a vactor truck. It is more pricy than CDF counting placement.
I like CDF because I can back fill a ditch quicker, with less labor and less question by inspectors. One person can backfill the ditch while the digging equipment is still digging and moving ahead. Thus, progress keeps moving on and a second machine is not tied up back filling in small increments. Back filling with compactable material seems to be a minimum of three people one placing material in the ditch however you do it, two people in the ditch one with a compactor and one with a shovel flattening out the high spots. Moreover, I repeat, in the ditch with all the BS that trying to work in a ditch entails.
Having one person walk down the ditch line steering a chute on a barrel truck is so much faster. The CDF is cheaper that the total cost of labor. Around here, even non-union work gets charged out at $90+ an hour to the customer. The cost of an operator and machine is way past that.
:my2c
:my2c
