I have a Freightliner tandem dump truck, Cummins L10, Eaton automatic tranny, 130,000 miles
Yes this is a Eaton automatic, not ultrashift, no clutch pedal
I have owned this truck for about 8 months and it has worked great, until a new driver, forgot to release the parking brake and drugged one set of tires, until it wore them to the rim (about 3 miles) Truck has automatic slack adjusters, so I guess just these two tires were tighter, than the others
Tranny worked good until this problem, now it wants to pause before going in gear, after you get it going it shift to high gear, then it will downshift into first gear and the tranny temp will start running hotter, it has gone to 230 degrees. I had the oil and filter changed in tranny, same thing
There is no one in my area that knows anything about this tranny, I was told the torque converter was messed up, about $4000 just for the torque converter, then labor to change it out and hope there is nothing else wrong, could be $6-8,000
Humm thats alot to invest in a 97, even though its a good truck
No the driver, is not working with me anymore
Anyone have any ideas
