transmission trouble on a fr 140 fiat allis loader
junkman33
arkansas
tries to pull in reverse trans pressure gauge reads normal check all filter and the sump screen and the diodes
FTV
Norway
Hi,
Not quite shure what you mean. Does it keep moving in reverse while in neutral? Or does it not move in reverse at all?
Regards
FTV
Norway
This troubleshooting guide: https://centranz.com/troubleshooting/ states warped discs and plates in the transmission as a possible reason for creeping in neutral. That's the best answer i can give you unfortunately. But there may be others on this forum with more knowledge on these transmissions.
Bigbert
Germany
Consulting Engineer
Does it lock in forward? At least at low engine speed?
Colour of oil? Smells burnt?
What type of transmission fitted?
junkman33
arkansas
oilis good not burned it tries to go in reverse does not move or creep back in neutral i set it up for a few years and this when the no situation came about
Bigbert
Germany
Consulting Engineer
Junkman, I'm definitely not a Clark expert, so no further assistance from my side given. Hope, the forum friends are able to give support.
