Greetings guys - as mentioned in title - i keep droping a track of on one side - its only just started to happen as a regular occurrence - here are the details
Its Komatsu pc 45 -
it is an older machine
track adjuster is not leaking and holding
always seams to be the same side
Steel Tracks - all idolers - rollers are in good order
with track of the ground - will drive nicely but you can see where the grease adjuster is , you can see it moving back and forward when track is running
driving on nice flat ground and making turning manuvers - its ok but once i get to slightly uneven ground or sandy ground - bank - out it goes
I know that its possibly worn tracks - but its just a farm tool , so really would like to avoid replacing expensive parts if possible as i make no money from the machine - is there a possibility of having to much tension which could cause this issue ?? as i know not enough can cause this
any suggestions ??
Its Komatsu pc 45 -
any suggestions ??
