towing
Brandx
new hampshire
how can i move a 1979 d3 tow or winch onto a trailer cant figure out how to search my words are to short thanks for the help
dozr
alabama
excaving
call a tow co they will help you and are most of time real close
Willie B
Mount Tabor VT
Electrician
Nice machine! You will want rock guards for the lower rollers. There aren't many with a hoe.
Wow it's been a minute since I've seen a dozer with a hoe. The trackloaders were somewhat common back in the day but I think I have only seen one dozer with a hoe on it in person.
That's got to be light on the front end with the hoe. It makes the front end a little light on a loader. The side guards for the rollers are only needed if you work in a lot of rocks. They pack up with dirt and accelerate undercarriage wear.
Willie B
Mount Tabor VT
Electrician
Sorry, I forget there are people who live where glaciers didn't come to die.
Here, there is no soil that does not contain rock. Even clay ground will have enough rock to chew up your idlers.
The dozers with hoe are less common than loaders with hoe. If they haven't added a lot of counterweight, you have to. It won't be good at grading with no counter weight.
Cat had counterweights that bolted on the back of the blade. Hoe has to come off to do any kind of grading.
Brandx
new hampshire
I may take the hoe off as I have a mini excavator. If I decide to remove the hoe I hope I could sell it, I have no idea what its worth. The controls are sloppy and both stabilizer cylinders leak.
Just make sure you don't run it with the hoses disconnected or you'll dead head the hydraulic pump. It won't have nice tight controls like a newer hoe but will still do a lot of digging. Cylinder seals can be replaced.
Yes but you need to remove the pins for the hoe, lift the hoe off the bracket, drive forward just enough to get at the couplers, shut the machine off, disconnect the hyd. couplers and hook them back together before you start the machine again. You can't unhook the hyd. couplers and expect to drive forward a few feet to have more room to reconnect them. Is a good idea to block the hoe up so it can't settle closer to the ground which would make it hard or impossible to hook up the hoses up if needed.
Brandx
new hampshire
Tha k you I cleaned the screen in the torque converter housing and it works like a charm steers both ways and stops as it should.
