I just did the same thing, moving this CAT 246
My plan was (and I will tell you now it did not go as planned) tilt bed car hauling trailer with 12k winch and snatch block pulling, Case 680 (I think? Big nonetheless) backhoe pushing. We used soapy water to wet the deck of the trailer, hoping to reduce friction. Loading it "kind of" went as planned.
Unloading it was where the **** show started. Plan was to tilt the trailer (still hooked to the truck), use another truck to drag it down off of the trailer and onto "car dollies". (4) dollies per side. Well, the dollies didn't handle the weight and their wheels failed to aid much in moving the machine into my shop. Ended up using my old plow truck to basically "man handle" it inside the shop.
Hindsight being 20/20, I believe I would have had better luck with the dollies, if we had not attempted to unload directly onto them. Although all (8) of them combined were rated to handle the weight of the machine, unloading directly onto them, exceeded the weight rated of the dollies as the machine came off of the trailer. We should have unloaded directly onto the concrete, them jacked the machine up, installed all (8) dollies, (4) per side under the tracks, then lower it back down. That would have been the only hope the dolies had to survive. Out of (8) dollies used, (4) were destroyed, (4) other wheels were destroyed.
My plan was based on the assumption the machine would move in straight lines as it was drug / pushed on and off the trailer. In actuality, it was all over the place, based on which track had the least resistance at the time. But at the end of the day we got into the shop, with no ER visits.
Live and learn I guess. Next time I know what to do different.
