Earthmachines
So not sure if you guys been following me at all on this backhoe project that I have going on 580 C originally I bought this back not running brought it back to my house. Did a compression test and elite down test as were coming in at 150 to 165 psi When I added a little bit of oil to the cylinders when the heads were still attached and did a compression test, my compression went up to a roughly 300 pounds after leak test my exhaust valves were clearly leaking during the compression stroke so I pulled the head off New valves valve springs valve guides valve seals and I have the head at the machine shop now getting new stuff installed but my question is while I have it apart. Should I put sleeves piston rings in it or just put the head back on and run it I don’t see any noticeable wear And there’s no ridge at the top of the piston on the walls like you would normally see from a worn cylinder wall and rings. I’m just wondering if the added oil in cylinders during a compression test actually sealed the exhaust valves as well I used a pretty lightweight oil stuff it was mystery oil so I imagine it would’ve pushed up to the exhaust Valves as well
