TLA (Trinidad Lake Asphalt) Milling
andoman
midwest
If it's natural asphalt it shouldn't be harder on your teeth unless they modified it with polymer.
Cairoh
Utah
If i'm reading correctly, it actually replaces a portion of the polymers in SMA.
andoman
midwest
The project we worked on was fully natural asphalt and everything went normally. If they used in as a modifier in PG binders it should mill normally, but the SMA's are a bit harder due to the stone structure, but not anything outside of normal.
