Matt Hyatt
Hi Guys,
Sorry to keep posting here for lame issues.... Seems every weekend I go out to start the skid and it's something different, and I'm totally new at this. Check the service manual but I don't really know where to start.
It ran fine last weekend once I sprayed the rad hose sensors. Now it will only turn over and make a black puff of smoke, about 3 separate times, and on the 3rd time, slightly higher RPM, but never starts. Then I reset the key position, and try again, and exactly the same results. I was thinking maybe the battery was low the first time and it didn't crank enough to combust, so it flooded? since I'm seeing all that black smoke? so I got a jumper on it and it's cranking hard, but same issue.
Could that be air in the fuel? Fuel stop solenoid? Any tips on where I should start?
