TL130, Left track won’t move
azvacs
AZ
Construction Co. Owner/Mechanic
Well after nearly a year, this Takeuchi TL130, (New to me) is finally running again, sort of. History is that I bought it back in Jan 2021 in sad shape and with a weak left travel motor but all hydraulics worked. Barely got it loaded and unloaded from the trailer and starting tearing it down. Very poorly maintained until now. Removed entire wiring harness, Replaced ALL filters, fluids, fuel lines, flushed fuel tank, drain and cleaned out hydraulic tank. Replaced missing solenoids and relays, repaired cut wires….. Got it back running today but no left travel motor movement. Machine is still up on blocks. I have no gauges or the knowledge on where or how to use them. You’ve all been great help with answers up to now so, what do i check next? I DO have a full set of manuals. Additional info is that previous owner did a poor engine swap (nothing put back together completely), so i plan on tracing all hydraulic hoses to confirm they are hooked up correctly
jimpad
ky
There's another thread about this. When mine does it I wiggle the stick from left to right while switching back and forth between low and high speed. Usually takes less than a minute and it starts working.
azvacs
AZ
Thx, I’ll try that.
azvacs
AZ
Which thread is it?
