I got lucky and had some help to mount some new tires on my skid steer. They are a pain but took air no problem once on the rims. I will say a backhoe stabilizer makes a great tool bead breaker. I used tire grease fairly liberally for mounting but a couple tires didn't quite seat all the way on to the wheel. There's about a 6-8" section that needs to go less than an 1/8" to fully seat. A couple guys said to run them and they may fully seat. The tires are rated up to 75 PSI so I left 70 PSI in them overnight. Will tires seat easier at the high pressure or would it be better to lower to what I normally run at 35 PSI. I've also read that warming the tires up a bit will soften them and they may seat. Has anyone had tires that won't fully seat? I wire brushed the rims prior to installing the new tires.
