Mannie
Hi my name is Mannie and I want to share my knowledge with you all , as we are one and others strength !
(How to avoid break failure )
If the reservoir of air tanks is full, it needs to be drained in order to check the performance of the brake system. Therefore, you should ensure the collected water has been removed from the reservoir. The main reason of doing this is to check whether the brake system is performing well or not. After doing this, drive your truck on an empty road and check the performance of brakes.
