Tips for removing nut on hydraulic cylinder
Steve111
New Jersey
Hey guys I have a case 580k. Trying to get this dang 2 1/4in bolt out of the end of this rod and having a hard time. Is there red loc tite in these threads or something? Had about 8 foot bar in this thing with no movement. How does everyone get these off? Should I be breaking out the torch to heat it up?
nova481
Howell NJ
Retired Union Electrician
Hi Steve
I just did the swing cylinder on my 580C. Yes, there is red thread locker on the bolt, all I had was a small torch with Mapp gas and a Harbor Freight laser thermometer. I propped the torch up right at the head of the bolt and let it get to 600 degrees, took 6 minutes. It came right off.
Ron
he probably means a 3/4" or 1" impact. Your 8' bar shouldn't have any problem, you just need to heat it. I don't think you have to get it 600, try it when the steel of the cylinder rod will sizzle a drop of water.
AzIron
Az
Yea 3/4 I put the 1 inch on a boom ram on a 420 last fall or get a multiplier I use a 4 to going back together I dont use the impact going back
We did a swing cinder that we didn't the luxury of an impact for use the multiplier with a 5 foot cheater and 250 pounds of lard ass you be surprised how well it went
Steve111
New Jersey
I am going to buy the 1in earthquake impact from harbor freight tomorrow and see how it does. Apparently rated at 2500 ft lbs. Good reviews too. I will update with results.
Any gun is only as good as the air. Do you have a 1" hose? there's ways to cheat a little...
Also, forgot to mention, once it's hot give the bolt a whack, and then put the lard on the cheater pipe.
Steve111
New Jersey
The one at harbor freight is rated for 1/2in hose. Going to do the entire setup and see how it goes. My ingersoll rand compressor has a 1/2in output at the regulator so I should be able to get most of The torque from it.
Steve111
New Jersey
Couldn't get it with the 1in impact. Maybe I can heat it up with the oxy acetylene torch first then let it cool? There is definatly red lock tite on these?
Surprise surprise. I have an old freon tank with a straight fitting going to a 3/4" hose about 4' long that connects directly to the gun, the tank fitting has a 3/8 air fitting coming in the side. You let the compressor turn on and once it turns off, your tank is full and you get one shot at the bolt before the air pressure drops, then you give it ten seconds and hit it again.
If you haven't gotten it loose yet, there's probably locktite. Try the cheater bar when it's hot, the heat softens the locktite, it doesn't remove it. What would you accomplish letting it cool?
Steve111
New Jersey
I just don't want to hit that bolt with all that torque while it's cherry red. I'm afraid of destroying the head of it
dieseldog5.9
New Hampshire
Check your compressors kick out pressure, work like that likes 150+ air pressure, 180 if you can get it, also I have seen guys hook up a 1/2 inch hose using 1/4 fittings kind of defeats the purpose.
Steve111
New Jersey
I have a single stage only so I got 135psi max. I hooked up directly to the regulator output which is 1/2 in and then directly to the air inlet on impact so I had no fittings. It's very strong. It was just that dang loctite that made it so difficult
I have never seen air tools rated for over 125 PSI. Most are rated for 90 PSI. Larger tools require more CFM but not more air pressure. That's why they make larger impact wrenches. Using over 125 PSI is bad advice in my opinion. It can be very dangerous to use too high a pressure. If a cylinder nut is that tight, take it to a shop with a proper cylinder bench.
Air flow for me is always the key, provided the pressure is up somewhere around the 120 mark, some manufacturers specify less. For example Ingersoll Rand call for "clean, dry air at 90psig maximum air pressure at the tool inlet, unless a higher pressure is specified on the tool."
My rule of thumb is that the air line diameter should be the same size as the drive on the impact wrench, so for a 1" wrench the hose should be 1" diameter, and make sure there are no bottlenecks such as restrictive fittings in the line. As an example I once found a 1" line that reduced to 1/2" to go through a filter, then stepped back up from 1/2" to 1" again - and people wondered why it wouldn't flow enough air for the air tools........... A bigger filter with 1" connections on it and voila...
