So the boot must be about 15 plus feet long with the platform for the guy extra and the operator must either go really slow or stop to allow for connections? That gives new meaning to the term of a small enclosed place to be, down in the boot. That's a new one on me, I've never seen anything like that before, is that a wolf plow in the picture? Thanks for correcting me, we've only ever put 20 footers of rigid in never knew they even made 10 footers before, I've asked about 30 or even 40 footers so I had less connections but nobody would make them for me but again I trench and then hook them up and toss them into the trench and then blind and backfill after.
Is that the same place that makes a boot to lay cement tile behind a plow? I heard about that from a salesman last fall that had seen the demonstration of laying cement tile behind a plow at one of the shows, the only upside to that last fall was they probably had something to put in the ground while everyone else was scrambling to find plastic tile to put in.
Just out of curiosity what do they put dual walled in for manure for? there's not usually that much distance to manure storage and most of that is dug in with an excavator? They aren't pumping it to the fields in dual walled are they? and if so how do they clean the lines out after they are done so it doesn't set up and plug the line for later?
