wornout wrench
I'm looking at a 2008 International 7400 single axle.
Ad says that it has a 300 hp Maxxforce with a 6 speed
After googling the specs on the truck, it would be a 6 speed stick with air brakes
I'm not sure which engine it is, the 466 or the 530.
Now, I know absolutely nothing about International trucks. I worked on a couple back in the mid 80's, now mostly K/W, Freightliners and Western stars, but I'm more into the stuff with tracks on it then rubber
What do you know about these trucks, good or bad
1) Engines any good
2) What are the most common problem with the engine
3) How is the wiring, any known problems
4) How dose the truck hold up to a bit of abuse. I am easy on the truck but westcoast logging isn't. Steep hills and some fairly rough gravel roads
5) Dealer support and parts. Any problems with parts. There is an associated parts dealer in town, just as long as things are available I should be able to get it
6) What is parts pricing like on International parts, not the regular stuff you can pull off any shelf?
7) One last thing, what are they like on fuel? About average or a bit of a pig?
So any experiences or thoughts on the subject will be most appreciated
Thanks in advance
Brian
The Wornout Wrench:waving
1) Engines any good
Thanks in advance
Brian
