BigWrench55
I was called out to a customer that had a turbo failure and replaced the turbo himself. He tells me that after changing the turbo the engine sounds like it's trying to run away. I remove the charge air pipes expecting to see the charge air cooler full of oil To my surprise the customer actually did a good job cleaning the oil out. I put everything back together and attempted to start it. With a lot of cranking it would try to fire. But then the oil would combust on the exhaust stroke and the engine would try to run backwards. I told him that the quick and easy way was for me to remove the injectors and flood the cylinders with brake cleaner. Then crank it over and blow out the oil. This is the question for thepumpguysc. When I pulled the injectors #4 and #2 injector tips were swollen. I never seen this type of failure before. This is a common rail fuel system. Did the oil in the combustion chamber get compressed back into the injectors? And would that type of failure along with the oil contamination cause the engine to want to run away? I personally never got the engine to run long enough to see if it actually tries to run away. After it misfired and started to run backwards I quit trying to start it. I am the third mechanic in this situation and don't have the full story of what is happening. I don't even know if the engine isn't harmed by any of this. The customer doesn't want to spend a lot of money. And I am only there because we are the dealer and the last resort after two other shade tree mechanics worked on it. The machine is a Volvo SD100F sheepsfoot roller and has a 4cyl Cummins teir3. I don't remember the model and my work phone with that information is at work.
