Looks good.
Now what will you use to chain to when loaded?
Maybe weld some D rings on the track frame?
Thanks, Jerry.
I have experience chaining a similar setup but this setup was a bit different and that method didn't work too well. At first I looped around the shoe because there is a lot of clearance between shoes where they round over the sprockets/idlers. When I released the chains this morning I saw some slight damage to the rubber. So I was not going to do that again. I had to really think about how I could make it happen. I cross chained the rear but obviously the bucket won't allow that method on the front. I really don't like cross chaining because I think the shorter the chain the better. So I think the method on the front might be a good solution. Take a look and see what you think.
This was how I did it the first time. Won't do that again.
This was a much improvement. I felt ok about this. It would require more time also.
These two pics show how I solved the front chaining. I felt really good about this. It got tight quick, chains are short, and it's not that time consuming which is a plus but not a priority. All we had left was a strap for the bucket but I already got a chain to replace that. Let me know if you think chaining to the steps is wise. It feels good and I'm adamant about load securement so I want the best scenario. Actually the rear cross chaining doesn't even contact the rubber shoes and the front does just slightly. This might be my best bet.
