Thought I should save anymore skimmers from making fools of themselves:
"But the boulders range in size up to about 100 tons. I'll try to get some pics next time I move the big rocks. For now this will have to do."
Yes, the front shovels push alot harder. If I'm up against something solid, it can usually push the machine backwards, and remember the grousers are alot deeper on these then standard excavators. However, on the ex700 It seems like only one of the rams pushing the arm is doing the work. When i detached them to transport it one wouldn't move with the stick like it was suppose to, guessing its only when the capacity of the other one is surpassed, otherwise one ram is being pulled by the other. The pc650 only has one 8" ram there where the ex700 has 2 6' rams. Like i said, the clamshell is very useful. Its *almost* like having a dozer/loader too. I'm not digging any trenches. And productivity, efficiency? Come on, this isn't a utility company. As far as the counterweight, i've been climbing a grade that i'm afraid it won't make it up with the counterweight. And there is no room to tow it out. I'd like to find a big winch to put on. I see the dozer winchs go cheap, but haven't seen a hydraulic one cheap-got enough projects. But it would be nice, i could use a crane block off the boom and lift a little more weight. The komatsu although dimensionally smaller is heavier then the ex700, the planetaries are bigger, the travel motors are compact and much of the boom is cast. It can actually hold its counterweight in the bucket and extend it almost all the way out before it tips. The PC650 was $11,000. Seriously youre going to tell me to buy a smaller machine? What can i get for $11000? I'm not going from job to job. If I was, i'd still stick with it and put the tracks on quick disconnects. I think it would be easier and much smarter then taking off the boom. The real reason I have two, was because they were at the same auction I won the ex700 first but couldn't pass on the pc650, I'm not one to backout. As soon as i have the bulk of the project done the ex700 will go. I'm not Canadian. But i realize its getting harder and harder to tell the french from the rest of us. ointhead :ban From Texas, now in Colorado. Holler if youre passing thru Denver.
